Crossmember and hub question
Old Nov 19, 2014 | 11:16 PM
one_fast_ef's Avatar
Default Crossmember and hub question
hey hondatech,
long time reader, first time poster...
Searched and searched but found no straight answer so if someone could chime in id appreciate it.
1. Im trying to replace the rear cross member in my 89 dx civic and i have a donor 91 dx crx...Are these two cross members interchangeable?
Also, are the hubs interchangeable between the two?
Ive searched and have gotten different answers so if someone could shed some light id appreciate it.
Old Nov 20, 2014 | 02:54 AM
meandino's Avatar
Default Re: Crossmember and hub question
The rear crossmember (beam) both have the same part number for manual transmissions. 50200-SH9-A00. As the Auto transmission have a different part number. 50200-SH9-A50. Maybe something to do with the power steering. So if the 89 and 91 both have manual or both have automatic then yes it would work. If one has manual and the other has automatic do some more research.
Source:
http://www.hondapartscheap.com/auto-...ine-mount-scat
As for the hubs according to the part numbers they are the same. Doesn't matter if they are manual or automatic. Used the same site for the source to check.
Good luck to you!
Nisif
Jul 13, 2005 08:28 AM
civicguy1984
May 1, 2005 06:06 PM
1995
Sep 1, 2004 03:41 PM
elmalouno
Nov 3, 2002 02:25 AM
s0liDyNe
Sep 18, 2002 01:31 PM
