Honda CR-V & Element 2WD & 4WD Element & CR-V
🔴 BRAKE BOOSTER PUSHROD CLEARANCE ? 🔴
Old Nov 19, 2014 | 02:43 PM
GTO3DEUCES's Avatar
Default BRAKE BOOSTER PUSHROD CLEARANCE ? TTT - Anyone ? Have an opinion or feedback ?
SUBJECT: 🔴 BRAKE BOOSTER PUSHROD CLEARANCE ? 🔴
Hello All,
Q. Is it ABSOLUTELY NECESSARY to perform the 'PUSHROD Clearance' step ?
{Section 19-18 thru 19-20} in the 2002-2003 CR-V Service Manual
A.
Q. Especially if the new Master Cylinder is a HONDA/NISSIN OEM swap out ?
A.
Thanks in advance for 'ANY and ALL' feedback and opinions !
DAVE LARKINS
65gtotrips@gmail.com
Call or Text To:
(610) 842•7905 cell
Last edited by GTO3DEUCES; Dec 1, 2014 at 01:28 PM. Reason: TTT - Anyone ? Have an opinion or feedback ?
Old Dec 1, 2014 | 02:46 PM
GTO3DEUCES's Avatar
Default 📌 RE: BRAKE BOOSTER PUSHROD CLEARANCE ? TTT - Anyone ? Have an opinion or feedback ?
GTO3DEUCES at 05:28 PM on 12-01-2014
HELP ? ? ? FEEDBACK ?
ANYONE have an opinion or feedback ?
🔻🔺🔻BRAKE BOOSTER PUSHROD CLEARANCE ? 🔻🔺🔻
🔶 🔹 🔶 ALSO...HAS ANYONE had to literally wrestle or pry the Master Cylinder off the studs and booster ? Mine "will not" budge off the studs and Booster...How 'ROUGH' can I get with it to get it off ? 🔷 🔸 🔷
Originally Posted by GTO3DEUCES
SUBJECT: 🔻🔺🔻BRAKE BOOSTER PUSHROD CLEARANCE ? 🔻🔺🔻
Hello All,
A.
A.
DAVE LARKINS
Call or Text To:
(610) 842•7905 cell
Old Dec 1, 2014 | 05:09 PM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: 🔴 BRAKE BOOSTER PUSHROD CLEARANCE ? 🔴
That girly text is just down right annoying. The distances and clearances are pretty important, with that being said if you aren't removing the brake booster I wouldn't worry about it. Changing just the master cylinder is rather common to do without checking anything, BUT when it comes to CR-Vs I am only very knowledgeable on the first gens so I can't help any further than that.
As far as the master cylinder removal goes - No, they usually just fall right off with everything removed. Give it a tap with a hammer. Worst case you will break the casting.
Old Dec 6, 2014 | 06:26 PM
GTO3DEUCES's Avatar
...hi...how are you ? Thanks for responding...
I.E. girly text...
...hey, the forum gives the tools to use 'BBCODE', so I prefer to to advantage of the formatting to help stand-out in the posts...
All the best,
Dave
http://flic.kr/p/qhorxN3"]
MTLian
Suspension & Brakes
15
Jun 28, 2018 09:35 AM
Innes
262
Jul 25, 2015 11:09 PM
eaz_e
Jul 4, 2011 10:11 AM
Project-Ek9
Dec 18, 2010 06:01 AM
dirk digler
Feb 10, 2009 04:49 PM
