cutting hole for sidemarkers on a crx? need to know where
A diagram on where to cut the hole? All I did was put them up against the fender where I thought they would look good, then made measurements......made it more precise than just where I had them. And then I just drilled the hole and then mesured the same amount on the other side and drilled the hole. Then since I wanted them to turn on when I turned on my parking lights and flash when I turned on the turn signal I wired them to my corner lense.
