Performance General Performance oriented Parts (Ex: Camshafts, Electronics, Air Intakes, Exhausts, complete engines)
KTuner ECU Packages, KTuner Reflash Systems all in stock! | HA Motorsports
Old Nov 19, 2014 | 08:45 AM
HAMOTORSPORTS's Avatar
Icon7 KTuner ECU Packages, KTuner Reflash Systems all in stock! | HA Motorsports
We are your KTuner authorized dealer for all KTuner End User systems and the new KTuner Reflash systems! All KTuner systems are available with a new ECU or we can install into your ECU for you. We stock all KTuner products and offer full product support from installation, troubleshooting, tuning, and any other help you may need to get the most from your system! Not sure if KTuner is right for you? Send us a quick email to sales (at) hamotorsports.com and we will be happy to answer any questions.
** All KTuner End User Boards are now the new Version 1 board with direct flex fuel support, 4 analog inputs, 2 VR/HALL inputs, and peripheral port for Bluetooth add-on **
What is KTuner? Simply put, KTuner consists of software for creating/editing your ECU's programming along with KTuner hardware that either installs into your ECU or plugs into your vehicles OBD2 port (depending on vehicle application). This allows you to fully tune your K series engine setup to run properly with your engine modifications.
The KTuner hardware is available in two different platforms depending on vehicle you will be using it on:
1. KTuner End User Board - Installs into 05-06 style K series ECU's. We can install the board into an ECU you provide, or you can order as a complete KTuner package with a new ECU. We have many ECU combinations available to fit a wide variety of applications. Each KTuner End User board comes paired with a software license for the KTuner software.
2. KTuner Reflash - This is a reflash interface that plugs into your car's OBD2 diagnostic port and allows you to reflash your stock ECU. You do not even need to remove your stock ECU/PCM - Simply plug the device into your OBD2 port and upload your tune/reflash and you are ready to go! Available for a wide range of newer vehicles from 06+ Civic Si to the 2014 Accord sport. Each KTuner reflash system comes paired with a software license for the KTuner software.
What can I do with the KTuner software?
Anything you could ever want from an engine management system - Change VTEC and VTC settings, REV limits, launch control, rescale for larger injectors, adjust idle settings, edit fuel and ignition tables, closed loop settings, and so much more. To add to your tuning pleasure, the software is a completely tab based layout with drag and drop features. You can setup the software layout anyway you'd like, setup whatever gauges you want, graphs, etc. just the way you want. Want to see some screenshots of the tuning software?
KTuner tab based layout with custom drag-n-drop features:
KTuner tuning/options example (showing disable/enable sensors options):
We have a KTuner system to fit almost any K series engine platform available:
02-04 RSX base and Type-S - KTuner / ECU packages in stock for this application!
05-06 RSX base and Type-S - KTuner / ECU packages in stock for this application!
02-05 Civic Si EP3 - KTuner End user board in stock, ECU package available for order
03-05 Element A/T and M/T - KTuner / ECU packages in stock for this application!
03-05 Accord 4cyl A/T and M/T - KTuner / ECU packages in stock for this application!
06-07 Accord 4cyl A/T and M/T - KTuner / ECU packages in stock for this application!
04-06 Acura TSX M/T - KTuner / ECU packages in stock for this application!
06-11 Civic Si - KTuner reflash systems in stock for this application!
12-15 Civic Si - KTuner reflash systems in stock for this application!
12-15 Civic R18 - KTuner reflash systems in stock for this application!
08-12 Accord 4cyl - KTuner reflash systems in stock for this application!
08-12 Accord V6 - KTuner reflash systems in stock for this application!
13-15 Accord 4 cyl - KTuner reflash systems in stock for this application!
13-16 Accord V6 - KTuner reflash systems in stock for this application!
07-08 TSX 4cyl - KTuner reflash systems in stock for this application!
09-14 TSX 4 cyl - KTuner reflash systems in stock for this application!
09-14 TSX V6 - KTuner reflash systems in stock for this application!
07-08 TL - KTuner reflash systems in stock for this application!
09-14 TL - KTuner reflash systems in stock for this application!
06-09 S2000 - KTuner reflash systems in stock for this application!
07-13 MDX - KTuner reflash systems in stock for this application!
09-14 Ridgeline - KTuner reflash systems in stock for this application!
09-13 Fit - KTuner reflash systems in stock for this application!
11-15 CRZ - KTuner reflash systems in stock for this application!
Want to see more? Check out the KTuner demo video on YouTube:
We have many more new applications under development and coming soon. Don't see your application listed? Send us a quick email and we can give you an ETA or let you know if it is available soon.
Have a question? Send us an email to sales(at)hamotorsports.com
Ready to check out the systems? Browse online 24/7 here: KTuner Tuning Systems, KTuner Reflashes | HA Motorsports
Old Nov 23, 2014 | 06:53 AM
Default Re: KTuner ECU Packages, KTuner Reflash Systems all in stock! | HA Motorsports
For those who are doing a K swap (K20,K24,etc), the KTuner system offers an excellent solution to your engine management. The KTuner 05-06 ECU Package we offer works with the 05-06 rsx engine harness, but can be used on swaps with an 02-04 style engine harness when combined with the KTuner Jumper Harness! In addition, our KTuner PRB ECU Package not only works with the 02-04 style speed sensor, but also works with the 05-06 RSX speed sensor so if you are using a newer transmission you don't have to find a work around for the different speed sensor!
Old Nov 25, 2014 | 08:56 AM
KTUner reflash systems in stock! Get yours ordered today. KTuner Reflash 06-11 Civic Si
Old Nov 26, 2014 | 11:05 AM
HA Motorsports | Honda Engine Management Specialists!
Old Nov 28, 2014 | 09:19 AM
Don't miss your only chance of the year to save on a KTuner system. All KTuner systems are on sale through Monday for our Black Friday savings event!
Old Nov 29, 2014 | 01:49 PM
ttt
Old Dec 1, 2014 | 05:55 AM
Bump for Cyber Monday!
Old Dec 4, 2014 | 08:10 AM
ttt
Old Dec 5, 2014 | 11:30 AM
ttt
Old Dec 6, 2014 | 11:26 AM
ttt
Old Dec 8, 2014 | 07:23 AM
ttt
Old Dec 8, 2014 | 03:10 PM
ttt
Old Dec 9, 2014 | 11:35 AM
ttt
Old Dec 10, 2014 | 07:38 AM
ttt
Old Dec 10, 2014 | 02:38 PM
ttt
Old Dec 11, 2014 | 02:32 PM
KTuner End-User Board Tuning System
Old Dec 14, 2014 | 12:52 PM
ttt
Old Dec 15, 2014 | 07:52 AM
ttt
Old Dec 16, 2014 | 09:57 AM
ttt
Old Dec 17, 2014 | 06:12 AM
ttt
Old Dec 17, 2014 | 02:44 PM
ttt
Old Dec 19, 2014 | 03:02 PM
ttt
Old Dec 20, 2014 | 12:31 PM
ttt
Old Dec 22, 2014 | 07:17 AM
ttt
Old Dec 23, 2014 | 01:56 PM
ttt
