Creaky Suspension
Old Nov 19, 2014 | 04:22 AM
coolswimmerjon's Avatar
Default Creaky Suspension
I have a 1997 Accord EX Wagon 2.2 VTEC. The front right suspension makes a metallic creaking noise (no popping noises yet). This happens when applying weight so the suspension travels up and down and also when turning the wheel from side to side, even when not driving. I can't seem to isolate exactly what part the noise is originating from. I was thinking it could be the lower ball joint. Any ideas on how to narrow down the possibilities or where to start?
Thanks
Old Nov 19, 2014 | 04:27 PM
holmesnmanny's Avatar
Either the lower ball joints or more likely the lower control arm bushings. You should just replace both if not already.
Old Nov 21, 2014 | 04:26 PM
Default Re: Creaky Suspension
So it turned out to be the lower ball joint. While I was in there I noticed that both the tie rod and upper ball joint boots were torn and leaking so I replaced both of those as well. Thanks.
chewe
Apr 9, 2017 03:41 AM
r_kage
Suspension & Brakes
Jun 9, 2015 12:41 PM
MechEng
Feb 18, 2015 05:58 PM
MechEng
Nov 29, 2010 04:27 PM
cho76ers
Jan 3, 2006 08:23 PM
