Chipped P06, P28 OBD1 ECU's, Custom Basemap Chips! | HA Motorsports
Looking for a QUALITY socketed OBD1 ECU for your engine setup? We have the socketed/chipped ECU configuration you've been looking for. All created from quality, hand selected ECU's that we've selected to fully recondition for your performance needs! Each ECU circuit board is fully inspected and cleaned, the ECU's casing receives our glass bead blasting, and the ECU lids are powder coated here in house with a high-strength hammertone powder coat for a long lasting finish. As far as the core of the ECU, we fully socket all ECU's with our chipping components using professional Hakko equipment, replace common weak points (capacitors, etc), and retest to be sure the ECU works flawlessly upon shipping. Trust our professional soldering skills with over 12 years of day in and day out circuit board soldering experience! You will not find a higher quality chipped OBD1 ECU than an HA Motorsports ECU. All ECU's are guaranteed for ONE FULL YEAR to give you plenty of time to test out your new ECU and be sure it surpasses your expectations!
For those running a non-vtec engine, we have our Chipped non-vtec P06 ECU:
Excellent for use with a Crome programmed basemap chip or to have tuned at your local dyno shop!
Looking for the ever-popular chipped P28? We have the Chipped P28 ECU in stock and ready to ship. Great for any D/B/F/H Series VTEC engine!
Need a custom program? Running a built engine or engine with larger injectors, turbo, etc? Take a look at our Custom Basemap Chips. If ordered at the same time with your new ECU, we will preinstall your new basemap chip into the ECU before shipping for a quick plug-n-play solution. We can create a basemap for ANY ENGINE CONFIGURATION! From the simple bolt-ons, to fully built turbocharged engines! Trust our 12+ years experience in tuning and creating basemap programs to configure an excellent basemap for your engine build!
Our custom basemap chips offer many extras:
* Changed REV limit
* Custom VTEC engagement
* Two step/ launch control
* Enable/disable not needed sensors, etc
* Custom shift light
* Performance tuned fuel and ignition maps
* Configure for aftermarket injectors
* Rescale for boost
* So much more!
Not sure what you need? Send us a quick email to sales (at) hamotorsports.com and we will be happy to help!
www.hamotorsports.com
have an OBD2 vehicle, but want to use one of our OBD1 chipped ECU's?
We have jumper harnesses in stock that you can add to your order for a one-stop solution. All of our ECU jumper harnesses use OEM connectors for OE quality fitment!
OBD2A to OBD1 jumper harness
OBD2B to OBD1 jumper harness
For those of you that are running an engine with IAB's (like a GSR engine with stock intake manifold, or H22, etc), we also offer a Chipped P72 ECU. This ECU is completely reconditioned just as our other OBD1 ECU's, but is built on the GSR ECU platform so it has IAB control and knock sensor board.
If you are interested in playing around with programming your own chips, reading other programmed chips, etc., we have the Moates BURN2 Chip Programmer / Reader in stock. This allows you to read a programmed chip, erase a chip, or burn/program a chip with your own basemap or tune. Simply plugs into your laptops USB port. Use Crome or any other chip-based tuning software to program your chip, install it into one of our chipped ECU's, and have some fun!
Want to datalog with Crome Pro? We have Hulog units in stock for quick shipping as well. The Moates Hulog allows you to datalog your ECU's sensors/signals easily when used with Crome Pro!
Have IAB's? Interested in a chipped P72 ECU? We have these available as well
Free stock engine basemap of your choice to get you running on your new ECU!
