No start. Cranks up But not firing
My 2001 honda doesn't start but cranks and turns over. I've replaced fuel pump, main relay, crank sensor shaft and installed a brand new battery. I need help!!
Fuel pressure is normal. I believe a fuse is blown because I've tried everything under the sun to make it start. Is it possible that my fuel injector is bad and does that cause an no start issue?
I would think if your fuel pump is kicking on that your ecu is commanding it on via the key. The fuse should be in the fuse box located under the dash. Let me ask you how you know fuel pressure is "normal"?
I checked the 15a fuse on my drivers side and it wasn't blown. But When the mechanic checked my fuel pressure. He touched something that made a lot squirt out and he said that my fuel pressure wasn't an issue. *Sorry I'm not specific with naming parts. I know little about cars**
I have found his test steps very useful. Please understand they are the work of another and he deserves full credit for providing this excellent information. I can only attest to the fact his procedures worked for me!
Is your Accord included in the Ignition Switch recall? My 1997 Accord was included. I found an excellent video on Youtube showing how to replace it. It is very simple. Please let me know if you are interested and I will find the link.
I hope this helps some. Best of Luck and I hope you are back on the road soon!
Sincerely,
Brían S. Du Bois
Evansville, IN
BSD
