hisseling sound exhaust drives me crazy !
Old Nov 15, 2014 | 08:44 AM
joytjuhhhh's Avatar
Default hisseling sound exhaust drives me crazy !
hey
i installed my catback and header and stil have a small leak but cant find out where.
under full load i hear a hissling sound inside of the car.
the sound comming from the front mid/passenger side.
when the car idles the sound isnt there,and whit light trottle the sound also doesnt appear
the catback tanabe medalion is from a del sol and modded it to fit an eg
the header is a plm tri y replica
between the header i installed a testpipe.
when i put a rag in the endtip of my catback and check for leaks
i cant see/feel anywhere presure/smoke/
al the gaskets are replaced only i didnt replace the gasket between the block and exhaust header,but it stil looks good
could this causing the problem ?
and why this accours with full thortle only?
all tips are welcome ,its driving me crazy !
Old Nov 15, 2014 | 02:06 PM
holmesnmanny's Avatar
Use some seafoam in the brake booster hose on a cold start and look for white smoke leaking out of the exhaust.
Old Nov 16, 2014 | 12:35 AM
joytjuhhhh's Avatar
Default Re: hisseling sound exhaust drives me crazy !
Thnx for your replay.
they dont sell seafoam over here.
My exhaust system is mounted with soms stress/tension ?
When i mounted the testpipe it was 0.5 to 1.0 cm to short.
When i bolted the testpipe down the midpipe moved a little toward the engine block.so the exhaust tip moved also al little inside
When you stress the engine, the block moves and maybe then pulling the collector between the testpipe and manifold....and then the leak appears...
Maybe i schould buy just and asjustble testpipe.....
Old Nov 16, 2014 | 12:18 PM
joytjuhhhh's Avatar
Today i looked at the blox air filter and saw 2 little damages ..could this causing the weird exhaust leak sound under full load
Old Nov 16, 2014 | 04:23 PM
F22Master's Avatar
Yes.
Exhausts dont hiss. Intakes do.
Old Nov 17, 2014 | 02:24 AM
joytjuhhhh's Avatar
Hey thnx voor you replay
i order a new air filter today en when its arrived il let you guys know of this
was the weird sound
but is surley sounds like an exhaust leak
DREADxPIRATE
29
Sep 10, 2009 08:34 AM
allricedout
Mar 14, 2007 06:33 PM
Racermech
Sep 28, 2006 07:55 AM
sittingonROTAS
16
Jul 21, 2006 10:35 AM
FourthGenHatch
14
Sep 13, 2003 11:19 AM
