1999 Honda Accord V6 Trannt rebuild
Old Nov 14, 2014 | 09:27 AM
tivo1's Avatar
Default 1999 Honda Accord V6 Trannt rebuild
I am having the tranny on my 1999 Accord V6 rebuilt. It has about 174K miles
Mechanic called as said, oil pan is leaking, CV boot is bad, rear engine mount bad and distributor is leaking oil.
Which of the above would not incur much additional labor since the transmission has to be removed for the rebuild.
I imagine that the CV axle would be disconnected to remove the transmission and as such I would only need to pay for the new part but not the labor. How about the oil pan? Car is a V6.
anything I need to replace given that the tranny is out and access to certain parts of the engine bay is now easier.
Thanks
Old Nov 14, 2014 | 01:12 PM
accordturb96's Avatar
Default Re: 1999 Honda Accord V6 Trannt rebuild
the distributor leak is usually a $4 o ring that takes a few minutes to replace. He will be removing most of those things in order to remove the trans
ang9999
Jun 29, 2018 12:42 PM
jc_ripzor
Nov 23, 2015 11:53 AM
Tasmero
Nov 8, 2014 05:36 PM
N3MeS1Sx
Sep 25, 2010 05:51 PM
Elvis1977
Mar 17, 2009 06:18 AM
