Honda CR-V & Element 2WD & 4WD Element & CR-V
2008 Honda Element codes for VSA warning light
Old Nov 14, 2014 | 08:50 AM
Patlee's Avatar
Icon2 2008 Honda Element codes for VSA warning light
Need help finding what caused the Element to kick out of cruise control and about ten miles later the VSA light came on. Took it to Advance Auto and here are the following codes which they said they had never seen before.
25-1 Yaw rate sensor
62-1 Battery voltage to high. Yet alternator test was good
74-1 Stem Solenoid valve #2
75-1 Valve #1
76-1 Apply Solenoid valve #2
77-1 Stroke switch #1
78-1 Stroke Switch #2
Any help to identify this problem would be greatly appreciated, money is currently tight with my wife going through chemo treatments and transportation is a necessity.
Old Nov 16, 2014 | 06:39 AM
Patlee's Avatar
Default Re: 2008 Honda Element codes for VSA warning light
Found this link but not sure if it helps me or not though: Malfunction & VSA warning lights activated
Still can't find a list of VSA codes for this vehicle or where the yaw rate sensor is located in the Element. Any info would be of considerable help.
Old Dec 27, 2022 | 07:54 PM
tedalmeida's Avatar
Did you ever find your solution? My 07 Pilot is doing something very similar. Thanks!
Old Dec 30, 2022 | 09:58 AM
uDraft's Avatar
Patlee has not been seen since 2014.
bigbookben
Aug 7, 2018 02:26 PM
Emccullough3
Sep 25, 2017 08:40 AM
mikulicz1955
Jul 6, 2017 11:39 AM
thefew
Sep 17, 2016 10:36 AM
