P3f valve reliefs with p8r head
Old Nov 14, 2014 | 05:30 AM
lzylst's Avatar
Default P3f valve reliefs with p8r head
I can not find the answer to my question after doing some searching.
Are the p3f piston intake valve reliefs bigger on the jdm motors that use the p8r head (33mm intake valves) or are ALL p3f pistons the same?
Old Nov 14, 2014 | 05:58 AM
darnizzle8805's Avatar
Default Re: P3f valve reliefs with p8r head
Same sized valve reliefs as all other b20 pistons.
Old Nov 14, 2014 | 04:07 PM
93egSLEEPER's Avatar
x2. The valves are not close enough to the piston for this to be a major concern.
Old Nov 15, 2014 | 04:26 AM
Factory cams aren't anywhere near the size of large after market Nonvtec cams, or vtec cam lobes. Unless you mill the crap out of the head.
Spawne32
Dec 21, 2010 08:47 PM
k20civicsi
Dec 9, 2009 11:38 AM
Tech6023
Sep 12, 2005 09:26 PM
gsrjay
Sep 2, 2004 05:05 AM
lsvtec101
Dec 5, 2003 01:20 PM
