B16 TPS problem code 7 obd0 wiring checks out new TPS
New TPS. Greenwire ground checks out. Yellow wire gets 4.6 - 4.9 V. Red wire has continuity/0 Ω back to ECU. Red wire back probed reads 20-40 mV at closed throttle, ~.35 V at wide open. There was no issue pre-swap (drove donor car home, TPS was fine.
Same red wire readings with old TPS.
Anyone know anything to suggest?
