b16a maximum engine temp ?
Old Nov 13, 2014 | 05:53 AM
gabrielsousa's Avatar
Default b16a maximum engine temp ?
whats the maximum safe temp on a b16a ??
99c ? or is to much
Old Nov 13, 2014 | 08:56 AM
4drEF's Avatar
Keyboard Humorist
Default Re: b16a maximum engine temp ?
Stock is best.
I don't understand what you are trying to accomplish.
More info please.
Old Nov 13, 2014 | 10:26 AM
If the b16a can run at 100c for a while without damage something
Old Nov 13, 2014 | 11:55 AM
4drEF's Avatar
Keyboard Humorist
Thermostat opens at 90c.
100c is the boiling temp of water (converts to 212f).
Average cooling fan switch kicks on at 191~197f (per Honda service manual for D-series, but probably the same for B16).
The engine takes a while to cool down, especially in warmer climates, so those engines will see 220f on occasion.
So really you are just going to be running about 15 degrees f hotter than normal.
You should be fine since you say only for 'a while'. Permanently or for a very long duration of driving it wouldn't be a great idea.
Water boils at 100c so make sure you are running 50/50 coolant mix. That raises the boiling point to about 129.5c
If you were hitting something like a constant 240f (115c) then there would likely start to become a problem.
Old Nov 13, 2014 | 11:57 AM
thanks
Jason Nucom
Dec 17, 2012 06:56 AM
si 1
Sep 24, 2006 01:51 PM
si 1
Sep 24, 2006 08:25 AM
