Main relay problems after fuel pump upgrade.
Old Nov 1, 2002 | 08:32 PM
cjmech's Avatar
Default Main relay problems after fuel pump upgrade.
My friend had his fuel pump replaced with a BBK unit and now we have gone through 2 main relays, its on a 91 CRX Si w/B16. It will run and drive but it will act like the key is being turned on and off really fast or just plain die.
Any ideas??
Cj
Old Nov 1, 2002 | 08:46 PM
USDM 4G VTEC's Avatar
Default Re: Main relay problems after fuel pump upgrade. (cjmech)
how do u know thge main relay its the one blowing??? does it clicks a lot under the dash while driving?? how much amp the ew fuel pump uses?? maybe u need to make sure wiring its good... its like running in a load,..
MrTodd's Avatar
Check the wiring on the pump itself, and also check the wiring harness that's located in the interior of the car, which leads to the pump. (the one just above gas tank, inside, underneath the plastic cargo trunk thing...)
It sounds like you've got a loose ground or something... It's most likely something to do with wiring.
Porkdizzle
May 5, 2011 05:28 AM
littlecrxVTEC
Dec 26, 2007 02:54 PM
Reelizmpro
Jul 10, 2005 06:33 AM
