How to measure rod bearings?
so i bought a b18b1 motor a few months back and not thinking i took it apart fully so its a bare block without thinking did lable bearings not lable which rods came out of were so my question is how do you measure rod bearings and does it matter which cylinder the rod goes back into
Inside micrometer isn't preferred but with the right feel you can get close. The preferred method would be a dial bore gauge. There are actually a few methods on how to get proper clearance and some of them don't require having bearings on hand.
I use an expanding 3-point inside micrometer for checking the bearing I.D. when torqued in a rod or main cap. The points have a small radius to get a single line of tangency and are next to impossible to mar the bearing surface.
is there a really good way and simple way to find out what size/color bearings i need since i dont have the origanal bearings on hand by the way im building/putting the motor back to gether to origanal specs
Interesting, but I have never marred bearings from using a dial bore gauge. Maybe you have much preload on the tool? Either way the OP was looking for a different direction obviously - no tools at all haha!
OP - You need to measure everything to make sure it is in spec before you proceed. If you don't care then just get the same color bearings you have on hand. Simple as that. There are marks stamped in that tell you the color code for the bearing on each journal. Just match the code to the bearing chart.
I've used a mitutoyo without incident but it was $500 . . . when it measured everything within .0001 of this brown & sharpe 3-point, I just started using the 3 point because its faster to setup.
a dial bore gauge or mic set are the best two options/methods, though they are not cheap tools to buy.
on a small budget some green "Plastigage" used per the instructions is a good "pass-fail" clearance check for a mostly stock, daily driven rebuild. high-performance, high-stress track-driven builds are worth the expense of proper measuring apparatus.
AssPenny
13
Feb 22, 2014 07:51 AM
bluedlude
39
Jan 27, 2008 12:42 PM
