H22, F20b and H23VTEC timing belt walk
Old Nov 11, 2014 | 04:47 PM
KStuned's Avatar
Default H22, F20b and H23VTEC timing belt walk
There's been so much talk about belt walk... here's some info.
We tested deflection on a brand new OEM idler pulley and measured it as tension was applied to a belt. There's a point that deflection stops, but the main point is that if too much tension is applied, the belt might walk.
As everyone knows, aggressive cams require more tension than stock or mild cams to avoid a floppy belt. The timing belt on the Outlaw car always hung off the cam gear a bit but it never bothered me. Anyway, here's the video. Enjoy and discuss.
Old Nov 11, 2014 | 08:25 PM
HiProfile's Avatar
Default Re: H22, F20b and H23VTEC timing belt walk
I've seen rubber grommets behind the pivot bolt (14513-RCA-A01) on some engines, so that may allow even more play & more walk for some people.
Old Nov 12, 2014 | 10:53 AM
KStuned's Avatar
I've never seen a rubber grommet behind that pivot bolt.
Old Nov 12, 2014 | 01:59 PM
H2296sol's Avatar
Do you see any longevity issues with side loading of the bearing?
Old Nov 12, 2014 | 08:41 PM
Bently_Coop's Avatar
Steve at Heart
Does the walk blocker come with your kits? Or is it a separate piece?
Edit: See it on the web page due to release 2015
Old Nov 14, 2014 | 07:49 AM
KStuned's Avatar
Because the force is so minor, I'm not concerned. It hasn't shown that it's an issue and we've been testing it for a while now.
Old Nov 16, 2014 | 09:27 AM
H2296sol's Avatar
Yeah, I couldn't imagine you would put this new part out with it having an issue. Just figured I'd ask, thanks!
Old Jun 6, 2016 | 06:22 AM
KStuned's Avatar
We changed our Youtube channel so the link went dead... fixed it!
dleccord
Apr 13, 2020 08:03 AM
CivicBlacksheep
46
Feb 10, 2013 09:51 AM
mattatchison
Jun 7, 2007 04:58 PM
nisecurrie
Aug 13, 2006 06:22 AM
huge230
Oct 4, 2005 12:31 PM
