Speedometer is possessed
Old Nov 11, 2014 | 09:14 AM
kenzo42's Avatar
Default Speedometer is possessed
I've read the many threads here, but I'm still having a tough time narrowing down what may be the culprit. Symptoms:
-bouncing speedometer that goes all over the place (seems to settle down after a while, but is NEVER accurate)
-cruise control works flawlessly
-NO blinking D4
-shifts perfectly
Can this still be VSS? Bad solder joints? Something else?
Thanks.
Old Nov 11, 2014 | 06:01 PM
accordturb96's Avatar
Default Re: Speedometer is possessed
well have you check the vss on the tranny? Made sure it is plugged in well and the wires are not cut or shorting? The speedo cluster could be going bad as well
Old Nov 11, 2014 | 09:39 PM
kenzo42's Avatar
Wouldn't a bad VSS cause cruise control not to work?
Old Nov 11, 2014 | 11:13 PM
slowcivic2k's Avatar
Dodge caravans are known for intermittent speed sensor problems. Is this what you drive. READ THE FORUM RULES DUDE!
Stupid info == Stupid answer.
Old Nov 12, 2014 | 05:15 AM
I could agree with you there, I thought about that after I posted. Without looking at the schematics I would be uncertain. But that does give you a direction to follow. You didnt post your vehicle so I dont know what you drive. Many of the accords have had issues with the speedo cluster
Old Nov 12, 2014 | 08:05 AM
kenzo42's Avatar
My bad. 95 Honda Accord Ex
Old Nov 12, 2014 | 10:03 AM
slomofo's Avatar
GDD Member
Contact the vatican and schedule an exorcist. If your speedometer truly is possessed, you need to deal with it immediately before the demons inside it end up hurting you or your family.
Old Nov 12, 2014 | 11:29 PM
kenzo42's Avatar
Vatican concluded speedometer wasn't a bonafide possession. Instead, they recommended I come to Honda-tech for help.
Old Nov 13, 2014 | 04:12 AM
94 accord typeR's Avatar
the vatican gave u some BAD advice LOL.
I went thru 3 VSS and 3 speedometers before i got 1 to work. not %100 accurate according to my GPS but maybe the GPS has 10 sec delay between the satalite.
rule of thumb: Check Engine Light (CEL)= VSS
no CEL = speedometer cluster
despite the negative comments civics need replacement clusters also
Teawins21
Jun 21, 2011 06:36 AM
cmasonrun
13
Jul 17, 2007 11:34 AM
blake92lude
Jun 16, 2007 10:07 PM
H.wood
Jan 14, 2006 12:13 PM
dc2vu
13
Sep 16, 2005 11:17 AM
