Grrr... 200k and timing belt never done?
Old Nov 11, 2014 | 03:51 AM
spazman2099's Avatar
Default Grrr... 200k and timing belt never done?
Hi folks,
This is a follow up thread to my earlier post about doing TB / water pump / head gasket / etc. on a 92 Accord. I got the crank pulley bolt off, finally, and it was torqued down so hard I think it has never been off before. The timing cover bolts seemed to never have been off either, and the timing belt is super loose... lots of slack. In my experience with other vehicles - I'm a Honda noob - timing belts should not be slack like that.
There's almost 200k on this car. Is it possible that the timing belt has never been done?
Old Nov 11, 2014 | 08:22 AM
accordturb96's Avatar
Default Re: Grrr... 200k and timing belt never done?
Yes its possible, anything is possible haha they swap them before 100k as preventive maintenance. You dont want to find out when the belt snaps. The tensioner could have gone bad as well and is creating the slop.
Old Nov 11, 2014 | 05:33 PM
holmesnmanny's Avatar
If it really hasn't been done and your car has 200k then the belt will be really beat up. If it's not, then it's been done before. I really can't think of a belt making it past 150k let alone 200k
Old Nov 12, 2014 | 02:43 AM
Fitz Williams's Avatar
10 Year Member
Years ago a friend had a 5-series BMW and drove it for 156,000 miles before the belt broke. They used to recommend changing that belt at 60,000, so you never know.
Old Nov 13, 2014 | 04:27 AM
94 accord typeR's Avatar
make sure u replace the cam seal and crank seal and maybe even the balance shaft seal.
but chances are that the belt was changed at lease once
delsolboi
Mar 13, 2013 11:57 AM
kai06
Sep 13, 2011 06:23 AM
yosuthnmasa
Apr 8, 2008 07:29 AM
pli
Sep 29, 2007 04:58 PM
eddiecut
Jun 16, 2003 12:10 PM
