96 accord 2.0L auto wont start
Old Nov 9, 2014 | 02:44 PM
Jordy LaForge's Avatar
Icon6 96 accord 2.0L auto wont start
Hey everyone, new to the forum and I am having some issues with my accord. It started a few months back, there was a minor flood in my area and the water went up to about the middle of the tires. When I left the affected area I got a mile or so down the road and the engine cut off. I waited five minutes and it fired back up but cut out on me a few more times before I finally got home. I figured something got wet and needed to dry out. Now here we are and it won't start at all. I looked underneath to see if something was fouled up, like a sensor or something, but I did not find anything. I checked the air filter, distributor, and replaced the spark plugs. All were fine except the plugs which needed replaced but when I pulled them out there was oil in the plug cavities. My dad told me that a gasket may have failed but it shouldn't affect it starting. What thoughts do you guys have on what is actually wrong with the car. When I try to start it, you can tell it wants to turn over but ultimately it doesn't. I'm pretty sure its not my battery or charging system, maybe fuel filter or pump, or its possible the fuel air mix isn't firing because f the oil in the spark plug cavities.
Old Nov 11, 2014 | 10:53 AM
19Accord97's Avatar
Default Re: 96 accord 2.0L auto wont start
It it truly was slightly less than the middle of the wheels, there shouldnt be too many electronic components other than the 2nd O2 sensor. Did water get inside the vehicle? If so, that is an entirely different situation.
I would change the oil to be sure you don't have water in it. Check out the negative power wire where it bolts to the transmission and make sure that it is properly secured without alot of broken wire strands.
Also check the tranny fluid.
Do you have a cold air intake? If water was sucked up while you were driving home that could be your issue too. Have you looked for blown fuses? Any CEL's? The oil in the spark plug tubes shouldn't be the issue as that is a very common issue - as long as the oil isn't between the plug and wire itself.
Old Dec 12, 2014 | 09:12 AM
UPDATE: I didn't find any water damage to the engine from that flood. I've checked the distributor and it was fine, I have spark and I have fuel but the car is still stalling sporadically and will not start for random amounts of time. I'm wondering if this could be my fuel pump going out, but I'm not really sure. Any thoughts on the cause of this?
Old Dec 12, 2014 | 09:53 AM
holmesnmanny's Avatar
You should compression to see if the motor may have got hydrolocked.
Jordy LaForge
Dec 12, 2014 09:09 AM
96accordlx_smh
Oct 20, 2014 08:32 PM
96hondaaccord26
Oct 7, 2014 04:50 AM
nilnew
Mar 2, 2005 05:18 PM
