91 accord charging system
Old Nov 9, 2014 | 10:59 AM
dslayden47's Avatar
Default 91 accord charging system
I have replaced alternator battery and check all connections..still shows not charging at battery..even checkex for shirts broken wires and still nothin vBulletin. ..when discounecting negative cable car dies..doez anyone know what I can check or replace next..old altornator had no out put..new one puts oyt 14 volts
Old Nov 9, 2014 | 02:08 PM
94 accord typeR's Avatar
Default Re: 91 accord charging system
battery positive connects to under-hood fuse box and starter
battery negative connects to frame and trans
i would suggest checking fuses, make sure negative terminal isnt loose. its possible since the old alternator was dead the old battery died too
Old Nov 9, 2014 | 08:13 PM
dahubby's Avatar
Get a load test on the alternator ( Free at autozone and Oreily). Could be possible you got a lemon.
Nick6
Aug 18, 2010 05:26 PM
VTEC_Du_Ma_Mai
Mar 20, 2008 04:48 PM
menace_yotc
Jan 11, 2007 01:38 PM
otip212
Oct 23, 2006 06:11 PM
idewson
Aug 31, 2006 11:45 AM
