fog light help
Old Nov 9, 2014 | 04:26 AM
SiRCD5's Avatar
Default fog light help
I recently got a 96-97 set of fog for my accord. only thing is I notice that the switch provided is not the same as the one I had on my 94-95 set. supposedly this set is for an SE model. the plug that goes into the back of the switch is smaller then that on the 94-95. I tried using a 94-95 switch with wires extended to see if the switch will power the fogs, but it did not. I do notice that one switch has 5 connectors(SE) whereas the regular 94-97 switch has 6 connectors.
has anyone gone through with this or know of a quick solution?
its the center console switch and id much rather not use it because it doesn't fit the space properly and looks a little off.
Is it possible to switch connectors so I can use the other switch, is so what would be the order of the wires...?
Old Nov 9, 2014 | 02:14 PM
94 accord typeR's Avatar
Default Re: fog light help
the 94-95 fog lights are different from the 96-97 fog lights. they also have different bumpers. the 94-95 fogs will not fit a 96-97. the button might be different also. u could use the 94-95 trim piece when installing in the center console since those are the same but u should use the 96-97 hardware
Old Nov 9, 2014 | 03:59 PM
SiRCD5's Avatar
Im gonna provide pics to better clearify.....
Old Nov 22, 2014 | 03:17 AM
SiRCD5's Avatar
Icon2 Re: fog light help
Both switches (SE/ 94-97 fog light switch)
SE wire colors (SE switch slightly smaller)
94-97 wire colors
*94-97 pig tail *
* * * * * * * *| B
| R/Y*
| R/B
| R/B * * * * | R ( silver dots)
SE pig tail
| *O * * * * * * | B
* * * * * * * * * * | R/W
* * * * * * * * * * | R/B ( silver dots)
* * * * * * * * * * | R/y
Tried connecting wires, was only able to get the switch to run constantly(would not operate the fog lights)
Any help in getting this to run right is greatly appreciated.
Old Nov 25, 2014 | 12:28 AM
SiRCD5's Avatar
.....anyone....?
Old Nov 25, 2014 | 01:50 AM
pastord's Avatar
Thought I saw an aftermarket kit for this at Crutchfield, but can't find the link at the moment.
Old Nov 25, 2014 | 10:22 AM
NerfGunner420's Avatar
http://www.wiringdiagrams21.com/wp-c...gram_thumb.jpg
Old Nov 25, 2014 | 10:30 AM
https://www.google.com/search?q=96+h...2F%3B467%3B705
Masho
Honda Civic (2001 - 2005)
May 16, 2010 07:20 PM
SigmaOmega
Jul 17, 2005 06:55 PM
BlazinITR
Jan 24, 2003 01:05 PM
uncleben
Jun 25, 2002 09:37 AM
Pengo
Mar 17, 2002 10:05 AM
