Parts List for a B-Series Swap?
Old Nov 8, 2014 | 04:41 AM
HondaCRZY's Avatar
Default Parts List for a B-Series Swap?
Hello,
I was wondering if anyone has detailed information on what is required for a B Series Swap into a 91 CRX Si.
Thank you
Old Nov 8, 2014 | 06:34 AM
Deetz's Avatar
Crazy Honda Guy
Default Re: Parts List for a B-Series Swap?
Pretty sure there a number of threads out there with this info, including the sticky up top, but i'll make a quick one off the top of my head anyway.
- any b series engine. Make sure the drivers side post engine mount is from a 90-93 integra or ef SiR
- b series cable tranny, or hydro version with conversion
- new clutch (flywheel optional)
- new rear main seal
- new themostat
- new timing belt
- new cap, rotor, plugs and wires
- b series engines swap mount kit
- 90-93 integra axels, including intermediate shaft
- ef SiR shift linkage, or custom swap linkage ie. Hasport
- 90-93 integra throttle wire
- 90-93 integra rad hoses, and rad is a great option too
That should cover most of it, i would cut any corners if you want a quality swap
F22Master's Avatar
Google
Old Nov 9, 2014 | 03:42 AM
HondaPartsHero's Avatar
Technical Hero
If it's b series VTEC you'll also need to wire up VTEC and the knock sensor. You'll need the corresponding ECU as well.
Old Nov 9, 2014 | 03:53 AM
smilindave's Avatar
see sticky section
Regards
Dave
Old Nov 9, 2014 | 11:53 AM
Former User's Avatar
PLEASE click on the Tyson's FAQs sticky at the top of the forum. There's a section dedicated to B-series swaps.
Carefully read information in those threads, and then return to this thread with only specific unanswered questions.
matt's hatch
Nov 18, 2010 11:21 AM
egonthree
Nov 19, 2008 09:47 AM
spens 91 Ef
Oct 26, 2008 05:26 PM
kpop
Northern California (Sales)
Feb 11, 2007 12:56 PM
shauniewalnuts
Apr 15, 2004 05:53 PM
