gsr rod bearing question (ACL RACE)
Old Nov 6, 2014 | 10:05 PM
ekx4's Avatar
Default gsr rod bearing question (ACL RACE)
I started rebuilding my motor today B18C1 GSR to stock specs. Im currently using acl race bearings for both main and rods. My question is when i plastigaged the rods from the timing side to the the clutch side it reads, .0015/.0015/.001/.001 isn't the .001 too tight or out of spec?
the service manual is saying
B18C1 engine:
Standard New: 0.032 - 0.050 mm
(0.0013 0.0020in)
Service Limit: 0.060mm (0.0024in)
am i doing something wrong or reading it wrong? i've plastigaged it more than a few times and coming out with the same numbers.
Old Nov 6, 2014 | 10:14 PM
OMG's Avatar
OMG
Default Re: gsr rod bearing question (ACL RACE)
what kind of rods
Old Nov 6, 2014 | 10:21 PM
ekx4's Avatar
everything is stock
Old Nov 6, 2014 | 10:33 PM
OMG's Avatar
OMG
green plastigage?
Old Nov 6, 2014 | 10:35 PM
ekx4's Avatar
yeah, http://www.aircooledtech.com/plastigage/plastigage2.jpg
Old Nov 6, 2014 | 10:52 PM
OMG's Avatar
OMG
when you put the bearings in, are the dry. no oil on the back
Old Nov 6, 2014 | 10:56 PM
ekx4's Avatar
yeah dry
Old Nov 6, 2014 | 10:58 PM
ekx4's Avatar
not sure if it matters, but the crank was micropolished and balanced
Old Nov 6, 2014 | 11:09 PM
OMG's Avatar
OMG
if anything that will make the crank smaller, leading to more clearance.
Maybe have your machine shop double check for you
tight rod bearing clearance is a no-no
Old Nov 6, 2014 | 11:18 PM
ekx4's Avatar
got'cha guess ill swing by there tomorrow.
Old Nov 7, 2014 | 02:49 AM
jimbo slice's Avatar
I second having a machine shop check clearances.
It is this exact reason why I won't use plasti-gage any longer. Too inconsistent in my opinion.
Old Nov 7, 2014 | 03:41 AM
Chugger's Avatar
you can always use the acl race x series bearings that will give you more clearence.
you can use one acl race h bearing and one acl race x bearing that will give you a little more clearence.
If you use both x bearing your clearence will be in the .0020 range but if you mix and match it will be in the .0015 range.
Old Nov 7, 2014 | 04:07 AM
Runnerdown's Avatar
One thing I have seen, is plastigauge not being used correctly on rod bearing checks. How do you seperate the cap from the rod? If you tap on the nuts or studs it will squish plastigauge if you have it under the cap side bearing. If you put the plastigauge on the rod side you have a better chance of not disturbing the material.
Old Nov 7, 2014 | 05:35 AM
ekx4's Avatar
i actually had it on the rod cap side and tapped the rod end cap left to right while pulling on the cap end until it came off, ill probably try it on the rod side to see if i get a different reading
Old Nov 7, 2014 | 06:00 AM
OMG's Avatar
OMG
nice work
Old Nov 8, 2014 | 02:22 AM
d15Beta's Avatar
make sure to use 30weight on the rod bolts
and torque to spec *not more
using other fastener lubes tend to let it glide more = lower torque values..
seen this happen numerous times when using ARP assembly lube
sometimes the figures are so small it doesnt matter..
but in ur case.. that small diff may well matter alot
HTH
Old Nov 8, 2014 | 03:04 AM
cruizinmax's Avatar
Is it possible the rod caps got mixed up? Do the numbers stamped on the sides of the cap match up?
Old Nov 8, 2014 | 08:58 AM
OMG's Avatar
OMG
for checking clearances I would use 50% tq instead of the full value
Old Nov 9, 2014 | 02:57 AM
m4xwellmurd3r's Avatar
Thats stupid. Clearences change based off torque value. 50% torque on my other block was ok. 100% torque mechanically siezed the crank because the journals were out of round in the block.
If you use 50% torque to check clearences you might as well be slapping a junk engine together for an engine blow show
Old Nov 9, 2014 | 12:41 PM
PyroProblem's Avatar
I usually never go full torque either during mock up. I feel it's better to not stretch the fasteners any more times than you have to. I go about 30% less. So far so good here but maybe I just been lucky.
Are you sure your since your mains were that far out that that was the reason the crank seized?
Next build I will measure the bores at different torque specs and observe.
Old Nov 10, 2014 | 01:39 AM
Yeah im sure. After I checked the clearances and saw how tight it was I used a telescoping gauge and it was pretty far out. Used a different block and all was good
Old Nov 10, 2014 | 08:52 AM
spAdam's Avatar
Loved
Community Favorite
Agree, sort of.
Nothing beats a mic and a detailed build sheet. Plastigage is great for doing a final sanity check and comparing to that build sheet to make sure the numbers are correct.
Wouldn't rely on it as my only measurement though.
JDM 98 GSR
K Series
Oct 27, 2011 11:09 PM
it a turbo
Sep 18, 2006 12:29 PM
B-B-K
Nov 9, 2005 06:39 PM
nkymain
11
Sep 22, 2005 01:25 PM
94civickid
Mar 15, 2005 02:10 PM
