Need Help Accord Wont Start
Old Nov 5, 2014 | 04:35 AM
Peter Lopez's Avatar
Default Need Help Accord Wont Start
Hey Ya'll
I got a 1991 Honda Accord that cranks but wont start. I desperately need some help at this point.
So far, I've replaced the distributor assembly, spark plug wires, spark plugs as well as the clutch disable trigger (button that is behind the clutch that nulls the starter when the clutch is not depressed).
Any tips is greatly appreciated. Thanks@!!!!
Old Nov 5, 2014 | 05:09 AM
alex1992's Avatar
Default Re: Need Help Accord Wont Start
check for fuel pressure or any fuel getting into the fuel rail.check if your fuel pump is working and also for spark and compression.i would check these three thing before throwing any parts at it.
Old Nov 6, 2014 | 06:14 PM
4cam4banger's Avatar
make sure your check engine light comes ON and then after two seconds or so goes OUT. listen for fuel pump. if your cel stays on then the main relay is no good.
Felipe_Rdz
May 8, 2013 02:27 PM
kcollings
Jan 29, 2013 02:59 AM
chickendance
Mar 12, 2012 03:48 PM
demian22
Nov 8, 2009 10:11 PM
bri1998
Jan 8, 2008 09:18 PM
