Name That Part! D15B2
Old Nov 1, 2002 | 05:59 PM
Hcivic88's Avatar
Default Name That Part! D15B2
hey, while the engine was going back in, i realized this piece was broke, one of the connections for a vaccum line had broken off, and i tried to glue it back on temporairly, then when I go to replace it, i have no idea what its even called
anybody know what it is?
thanx
[Modified by Hcivic88, 7:00 PM 11/1/2002]
Old Nov 1, 2002 | 06:11 PM
USDM 4G VTEC's Avatar
Default Re: Name That Part! D15B2 (Hcivic88)
my manual calls it the TDS sensor
Old Nov 1, 2002 | 06:13 PM
Hcivic88's Avatar
Default Re: Name That Part! D15B2 (JDM EF9)
thanx
what exactly is a TDS sensor though?
Throttle Dashpot Solinoid?
[Modified by Hcivic88, 7:19 PM 11/1/2002]
Old Nov 1, 2002 | 06:20 PM
doesnt really say
why u wanna know? is it broken???
Old Nov 1, 2002 | 06:22 PM
Hcivic88's Avatar
well, the stem that the vaccum line went onto, like the line slides ontop of it, its a plastic stem and when it broke i tried to temporairly fix it with superglue, and since then my idles been all messed up, so im figuring i should replace any broken things first, then start looking for other broken things that could cause that problem, cause it could be this sensor thing.
and i had no idea what it was even called, now i just gotta figure out what a TDS sensor is, lol
thanx a lot for your help man,
someones gotta know what a TDS is
[Modified by Hcivic88, 7:24 PM 11/1/2002]
Old Nov 1, 2002 | 06:28 PM
have u tried getting that from a junkyard??
if u dont have any around, let me know theres plenty around here.. i got a D15B1 with one of those here... so let me know if u need this
Old Nov 1, 2002 | 06:34 PM
Hcivic88's Avatar
theres a few junkyards around here that i'll have to check out, I just never knew what the part was called, cause here you tell the people what u want and they go get it for ya, i just wanna figure out what TDS is though, and what exactly it does so i can find out if it could be the problem.
if i cant find anything ill let ya know
would u be willing to ship to canada though?
Old Nov 1, 2002 | 07:48 PM
89 CRX SI's Avatar
did you reset your ecu pulling hazzard fuse for 15 sec? i did that to my bad idle and it works perfect now
Old Nov 1, 2002 | 07:49 PM
89 CRX SI's Avatar
your car has to be heated up tho and then shut off then pull replace and start up
dont know why it works cause i wasent throwing any codes
Old Nov 2, 2002 | 03:41 AM
Hcivic88's Avatar
Default Re: Name That Part! D15B2 (89 CRX SI)
yeah, i thought that might work too so i tried pulling the hazzard fuse, but its stil all nuts.
nobody knows what a TDS sensor is though?? I'm surprised
EF-8SiR
Feb 23, 2009 07:27 PM
integrag
Mar 9, 2008 09:56 AM
musclefella
Apr 15, 2004 09:12 AM
navin
May 28, 2002 10:39 PM
