ls/v motor help
So here's the thing, I've got marks in the Pistons from intake side valves only. The block is bone stock pr4. Crank, rods and Pistons. Head is b16a with b16 cams, valve train besides forged flat top valves. Motor ran great for about 3k miles until all of a sudden the valves were hitting the Pistons. Any ideas? This is my daily and building the motor further would come later down the road
I thought this as well, but it would probably be running like *** too. If your springs are THAT bad on B16 cams you are lucky you didn't hit more problems. B16 cams are tiny the and Pr4 pistons are considered "dished" or negative dome
I am a little skeptical about stock b16 cams creating valve float.. Seems like there is an underlying issue that needs to be resolved. Or someone needs to set a rev limit
Valve pockets on PR4 pistons are also tiny in comparison to VTEC pockets. And the dished area is too far in to effect piston to valve clearances.
I'm strapped for cash but I'm almost willing to work extra over time and getta another stock head but could run into different issues with that.
Check to see if tdc is still true. Only way a valve can hit a piston if the belt slipped and jumped a tooth, or the spring has been weakened due to you revving it so high..
Replace the springs first. As was said before, the pr4 pistons have a negative dome so you are most likelyexperiencing valve float at a lowered rpm. Stock head studs also? Change them along with the headgasket. See what happens.
redlshatch
Feb 8, 2006 12:25 PM
Dan GSR
Jan 14, 2004 04:10 AM
