What to look for in a 92 honda accord ex.
Old Nov 3, 2014 | 02:40 PM
Pyramid's Avatar
Default What to look for in a 92 honda accord ex.
Alright so I have some Honda knowledge, but what should I look for when looking at a 92 accord?
I'm about to go look at one n need help..
Here's info:
1992 honda accord 4-door sedan odometer: 216000 paint color : grey size : full-size type : sedan drive : fwd fuel : gas transmission : automatic title status : clean cylinders : 4 cylinders
92 honda accord ex 2.2L auto. New head gasket and seals. New valves and seals. Vehicle needs either a new transmission computer or current one rebuilt. No reverse gear has all forward gears. Needs a new battery or current one fully charged. Starts and drives.
I can get it for 400 dollars..
http://images.craigslist.org/00n0n_k...fQ_600x450.jpg
http://images.craigslist.org/01010_h...Cp_600x450.jpg
http://images.craigslist.org/00e0e_4...8t_600x450.jpg
http://images.craigslist.org/00X0X_4...rF_600x450.jpg
http://images.craigslist.org/01111_8...oo_600x450.jpg
http://images.craigslist.org/00101_9...8h_600x450.jpg
http://images.craigslist.org/00o0o_3...Z6_600x450.jpg
http://images.craigslist.org/00p0p_2...CD_600x450.jpg
http://images.craigslist.org/00B0B_1...AC_600x450.jpg
http://images.craigslist.org/00d0d_8...km_600x450.jpg
Old Nov 3, 2014 | 08:46 PM
holmesnmanny's Avatar
Default Re: What to look for in a 92 honda accord ex.
Atleast he's nice enough to tell you that the tranny is fucked up. I would avoid that unless you know how to swap out a tranny, which I do. But I only stick with manual cars.
Old Nov 4, 2014 | 09:18 AM
masospaghetti's Avatar
With most cars, you can rack up some big $$ on a cheap car if it needs tires, brakes, axles, and suspension work. If the car is in good shape other than the tranny, then it might be worth it. I don't know what would cause reverse to drop out.
Also check the flex pipe. They seem to be a common failure, if you see black soot around the flex then it's probably blown.
Old Nov 6, 2014 | 06:16 PM
4cam4banger's Avatar
i REALLY doubt reverse is a tcm issue. i think it needs a transmission.
check for oil in the spark plug tubes, rear wheel well rust if youre in a rust prone area.....
not much goes wrong on cb7s other than tcms and main relays.
coupeman
Mid-Atlantic (Sales)
Jun 15, 2011 07:38 AM
coupeman
Jun 15, 2011 07:37 AM
TeamCeper
Jun 3, 2008 10:45 PM
