Clutch master cylinder help?
Old Nov 1, 2002 | 05:34 PM
Accord15's Avatar
Default Clutch master cylinder help?
I just installed my clutch master cylinder and slave cylinder and the pedal is dead it is either all the way up or on the floor. What could be the problem? Thanks
Old Nov 1, 2002 | 05:58 PM
Conechaser's Avatar
Default Re: Clutch master cylinder help? (Accord15)
air in the system somewhere.
Old Nov 1, 2002 | 06:29 PM
Nick H's Avatar
New User
Default Re: Clutch master cylinder help? (94Accord)
bleed bitch bleed!
Old Nov 1, 2002 | 06:31 PM
Accord15's Avatar
Default Re: Clutch master cylinder help? (Nick H)
i have tried to bleed the system it won't work. How can i bleed it if the pedal is only all the way up or all the way down?
Old Nov 1, 2002 | 06:32 PM
Brandon's Avatar
Life is Suffering
bleed bitch bleed!
Well put.
Old Nov 1, 2002 | 06:35 PM
Brandon's Avatar
Life is Suffering
You need 2 people in order to bleed it quickly, but just pull the pedal back, open the valve, push the pedal down, close the valve, and when it is back to the right feeling, then bleed it a couple more times and then you're done. Just be sure that the MC does not empty while you are bleeding it or else you'll be SOL.
Nick H's Avatar
New User
Default Re: Clutch master cylinder help? (Brandon)
if it's all the way up then you should still be able to force it down...or if that doesn't work just try draining all the old fluid and going from there...good luck dude!
Old Nov 1, 2002 | 08:11 PM
Accord15's Avatar
damn advance auto one man bleeder my ***. I'll give it a whirl in the morning i spent about an hour getting the codder pin off of the bolt or whatever that holds the master cylinder to the pedal. I was so freakin pisses what a pain in the dick
Ashwell33
Transmission & Drivetrain
Feb 15, 2019 11:54 AM
JDMswagSerf
Dec 10, 2013 09:47 PM
autoxthis
Sep 18, 2008 12:50 PM
autoxthis
Honda Civic (2006 - 2015)
Aug 24, 2008 05:46 PM
itsJDMyo
Oct 24, 2005 05:02 PM
