Actron CP7528 Advance Timming Light might be off? Civic 99 EX
Old Nov 3, 2014 | 05:45 AM
rovafa2002's Avatar
Default Actron CP7528 Advance Timming Light might be off? Civic 99 EX
Hi there,
I have been using this CP7528 Advance Timming Light for a couple of years now on my 99 Honda Civic EX. On this Car I have a total of 4 timming marks in my Harmonc Balancer in these order:
- 14 BTC
- 12 BTC (Stock)
- 10 BTC
- TDC
The problem I always saw is that If I set my timming by pointing to the TDC mark (with the gun **** at 12 BTC), then I recheck by setting the **** to 0 and pointing to the 12 BTC stock this doesn't line up. So at this point I dont know which will give me the correct reading, if using the first or the second method.
Any ideas or know related issues about this?
Old Nov 3, 2014 | 05:51 AM
Former User's Avatar
Default Re: Actron CP7528 Advance Timming Light might be off? Civic 99 EX
Are you following to a tee the service manual instructions for checking the ignition timing?
How different are the readings?
Old Nov 3, 2014 | 06:27 AM
rovafa2002's Avatar
Yes, I am jumping the Service Port so my Check engine light will be on. So If y Measure by pointing to the TDC (the most easy to view) with the gun at 12btc and then I recheck by putting the gun at 0, the 12 btc mark doesnt line up.
And If I do the opposite Line up the 12 mark with the 0 and then try to line up the TDC mark by moving the know It will be at 13,5 btc.
Old Nov 3, 2014 | 06:32 AM
It will be at 13,5
So are you saying the reading is off by 1.5-degrees?
Are you monitoring the idle speed to ensure that the engine idles identically to spec for both readings?
jeffbrewer80
12
Sep 26, 2011 12:28 PM
honda4fun
Jun 11, 2009 04:09 PM
FFFreddYYY
May 14, 2008 06:22 PM
