Pro2's with Super tech valves and valve springs?
Old Nov 2, 2014 | 04:05 PM
NEEK94LS's Avatar
Default Pro2's with Super tech valves and valve springs?
Hey guys
Anyone running SK2 PRO 2's with Supertech springs and/or valves on a B series? I just bought some pro 2's for my all motor GSR and I want to start on my valve train now. I know SK2 recommends pro series valve springs but is it possible to get the same results using supertechs springs instead? Ive heard good things about them and they seem to be a nice amount cheaper than Skunk2.
Any input on this is appreciated.
Old Nov 2, 2014 | 04:12 PM
NEEK94LS's Avatar
Default Re: Pro2's with Super tech valves and valve springs?
Old Nov 2, 2014 | 04:16 PM
slowsleeper's Avatar
I've had success with Supertech springs, just make sure your clearances are good.
Old Nov 2, 2014 | 04:40 PM
NEEK94LS's Avatar
Thats very good to hear, you were using Pro2's ?
Old Nov 2, 2014 | 05:06 PM
Yes. I've used Pro2s with Skunk2 Pro series springs, Rocket SL springs, Supertech Springs, and Ferreas. All have been fine, obviously there are many variables whether parts will work or not. Just make sure u have proper clearances and you'll be fine.
Old Nov 2, 2014 | 09:24 PM
93egSLEEPER's Avatar
I've had luck w/ supertech in the past as well. Good parts for a good price.
Old Nov 3, 2014 | 05:56 PM
NEEK94LS's Avatar
Decided to go with a supertech setup today. I gave real street performance a ring and got some much needed help. The guy I spoke to gave me a pretty damn good deal plus he got points for being, polite, professional, and on point. I belive his name was Trevor. .. anyway kudos
NEEK94LS's Avatar
Anyone else who has info on this topic please chime in
Old Nov 3, 2014 | 07:40 PM
OMG's Avatar
OMG
to give you an idea of how much pressure to use, 55lb Rocket Motorsports SL springs work fine with most cams to 12,000 rpms
SLs are also good enough for some 700whp turbo engines in North Carolina
Old Nov 4, 2014 | 12:56 AM
Lonewolf1983's Avatar
I went with supertech springs and Ti retainers
and OEM sping type LMA's
Old Nov 4, 2014 | 02:51 AM
Chugger's Avatar
i ran the h100dr on roller cams without any issues and ran the lighter spring rate st's on a set of toda c's without any problems at all.
Old Nov 5, 2014 | 03:46 PM
NEEK94LS's Avatar
Lol 12k rpm.... is that that rotary mod.
Still thats good to know I only plan on taking him to 8500-8700
Old Nov 5, 2014 | 03:47 PM
NEEK94LS's Avatar
I was actually thinking about the Skunk2 LMA's. Seemed like it was worth it.
Old Nov 5, 2014 | 03:50 PM
NEEK94LS's Avatar
I was actually talked in to getting the h100d's. Guy said the dr's were usually used for turbo setups or really aggressive cams.
Old Nov 6, 2014 | 12:44 AM
some people think they're fine, others i've heard of sagging.
Honda OEM only cost me $20 more so I went for them
Old Nov 6, 2014 | 01:51 PM
Vinnie909LSVTEC's Avatar
Check my build, Im running pro 2s with supertech valves/springs and skunk2 LMAs its been running great for me!
Old Nov 10, 2014 | 05:08 PM
whitesihatch's Avatar
The st have more seat pressure over s2 so no harm done. I personally would run st Just for the peace of mind.
Old Nov 11, 2014 | 03:20 AM
NEEK94LS's Avatar
Sagging? Thats not good
Old Nov 11, 2014 | 03:22 AM
NEEK94LS's Avatar
Definitely going to check that out
Old Nov 11, 2014 | 03:32 AM
NEEK94LS's Avatar
Yes but I dont want to much seat pressure. I actually ended up going with ST's H100D springs. Got a good deal on them too (yay me lol)
Old Nov 11, 2014 | 02:13 PM
1HGEJ2's Avatar
what is sagging?
my friend install s2 springs and s2 lmas..and it makes some dieselengine sound but works great.
