92 Accord Disappearing and reappearing oil
So my 92 Accord with a 2.2L 4cylinder engine is acting up! I check the oil one day after letting it cool for a few hours (4-6 hours) and the oil stick says its low. I add the needed amount drive it around. its fine, let it cool for a while and check it again and all of a sudden it has a lot of oil in it! Just past the max line; I drain the oil, check it, its fine. But it happens again and again; what's happening?
Its leveled, and it changes regardless of level. I do it at home, it changes, I do it at work it changes. Me and my mechanics are confounded by it! We have no idea, I usually don't take it to mechanic cause I like to think I'm handy with my car but poops am I and two other mechanics are stumped!
Does all 4-5 quarts of oil come out when you change the oil?
Reason I say that is I've seen oil turn tar-like and read the same way. When I did oil & lube they had this stuff that turns it back to liquid. You put like 8-10 ounces in the oil, run the vehicle for 60 seconds and it all drains right out.
You might check to see if you have blown head gasket. Water seeping into your oil as the engine cools, thus raising the volume of liquid in your oil pan.
Just a thought.
Just a thought.
Talk about an oil filter going bad: Car and Driver uncovers trouble with Corvette Stingray's LT1 V8 - Autoblog
Did that now! Checked the head gasket looks good to me but imma get a second opinion just in case! There`s no leaks and the oil looks fine -- it suppose to look milky if it does right -- coolants good. Like I said just in case
Do you know what the liquid is called, if not I`ll ask tomorrow at Autozone or something
You don't need to redo the oil, just replace the filter. Please update this thread if it fixes it for the next guy that has this problem.
Don't try to skimp on oil filters. It's basically a 5 dollar price difference from the worst to the best of any brand.
meangreenEG
17
Jul 28, 2007 11:36 AM
1baddturbosi
Dec 7, 2006 05:02 PM
