HELP wont start & dont understand why!!!
Old Oct 30, 2014 | 04:27 AM
Grumpys's Avatar
Default HELP wont start & dont understand why!!!
Ok so i have a 2000 civic ex coupe that sat in my heated garage a yr or longer. Ran fine when we parked it other then burning some oil. I've put a new battery,starter,coil,ign module,plugs,fuel filter,cap & rotor and still no start. It's getting spark off all 4 wires, all 4 plugs are getting gas,but it try's to bark once then it just cranks & gets slower each crank i don't get it how can i have fuel, spark, and still no start. Compression is 180 cyl 1, 180 cyl 2 , 180 cyl 3 , 120 cyl 4 , but im lost on what this could be so Please Anyone with some experience HELP ME. Can't believe that cyl 4 being that different will cause a No Start!! Please someone HELP me...
Old Oct 30, 2014 | 04:44 AM
Former User's Avatar
Default Re: HELP wont start & dont understand why!!!
Check the mechanical timing. If good, do a leak down test on cyl 4.
Old Oct 30, 2014 | 05:34 AM
09chaplak's Avatar
Loves Tossing Salad
hahaha I was reading along and read past the 120 and was like wait.......180, 180, 180, 120?! That might cause some issuesssssss
Old Oct 30, 2014 | 09:09 AM
Grumpys's Avatar
Well checked timing & from what i can tell hard time seeing inside white line. But used a hacksaw blade down through pointer and it looks Good. I don't have a leak down tester nor have ever used one. But looks like that is why it wont start then cause #4 is so low psi?
Old Oct 30, 2014 | 09:13 AM
Most likely. I asked about mechanical timing because there may have been a piston-valve collision. You could post pics of the cam and crank TDC1 alignments if you need verification.
Old Oct 30, 2014 | 09:35 AM
Grumpys's Avatar
I'm pretty sure there was no piston-Valve collision. I just find it hard to believe cause of it sitting that all of a sudden it wont run. When it did when it was parked. I'll have a buddy verify TDC for me not sure if i'd be able to get a good enough photo right now. Thanks so much for the Help I appreciate it!!!
Old Oct 30, 2014 | 09:39 AM
I'm not so sure, but proper diagnostics for loss of compression should sort things out.
Ek9_Cuhzz
58
Jan 7, 2011 04:54 AM
mrportugal4
Jun 18, 2010 11:42 AM
gldeneaglelude216
Nov 25, 2008 04:26 PM
Bngo731
Jun 5, 2006 02:42 PM
