Classic Hondas All Pre-1988 Hondas.
Y8 into a 1986 crx
Old Oct 29, 2014 | 05:49 PM
1turbocivic's Avatar
Default Y8 into a 1986 crx
I'm really hoping this swap has been done before. I'm needing help with wiring. Any info or suggestions are much appreciated. Thanks in advance.
Old Dec 21, 2014 | 10:05 AM
digdug18's Avatar
Default Re: Y8 into a 1986 crx
Not really done. Most people seem to swap in the ZC motors, because it's a straight forward swap. Or perhaps a Blue top or Black top integra motor.
you'll be on your own, but gladly there isn't that much wiring to do, and if you have a manual from each car, or use a standalone computer, it'll be pretty straight forward.
If however you are expecting aftermarket support for putting a Y8 into an 86 crx, then you'll figure out quickly that the market for the crx is so limited, most shops don't care if you are doing the swap or not. They can't make bank off of a one off part. So you'll have to use off the shelf parts or make your own.
Old Jan 12, 2015 | 05:06 PM
Na-Spirit's Avatar
AFD2? - D-Series (AF) - 84-87 Civic/CRX (AF) - Civic/CRX - Mounts Mounts for a D
Call up Rywire for a custom "budget" harness..Im sure he can educate you whats needed to do the swap.
Also check out redpepperracing.com
Old Jan 14, 2015 | 06:42 AM
E-AT_me's Avatar
With your original post you gave an amazing amount of information... not.
is your crx fuel injected or carbed?
MR.ej7
Dec 5, 2012 10:09 AM
s3xrapt0r
Oct 20, 2011 07:41 PM
hondahatch91
Classic Hondas
Nov 16, 2008 03:07 PM
JokerX-1.6T
Mid-Atlantic (Sales)
17
Jan 17, 2007 04:48 AM
PFSeg
Oct 19, 2004 07:23 PM
