92 Civic Hatch SI Starting issues
Old Oct 29, 2014 | 08:00 AM
fmxrydr's Avatar
Default 92 Civic Hatch SI Starting issues
So I have tried to search multiple forums for someone having issues similar to mine but have had no luck so maybe someone can help me out a bit. My issue is that I can start the car up just fine from a cold start but after the car has ran a little bit, and it will run till I turn the car off. But after it's been turned off and if you try to turn the car back on it won't start up and you have to wait between 3-10 minutes before it will start up again. I have recently done a motor swap and just put in another d16z6 motor. Have tried to check plugs, wires, fuel all seem to be working well. Im still new to the honda world so maybe you guys could help me out with some other things to check.
Thanks
Old Oct 29, 2014 | 08:30 AM
Former User's Avatar
Default Re: 92 Civic Hatch SI Starting issues
When the engine won't restart warm, is it a no-crank problem or a cranks-but-won't-start problem?
Old Oct 30, 2014 | 05:46 AM
fmxrydr's Avatar
It will crank but just won't start.
Old Oct 30, 2014 | 05:50 AM
When it won't start, does the fuel pump prime?
Spark at all 4 plugs?
CEL codes?
Old Oct 30, 2014 | 05:53 AM
fmxrydr's Avatar
Fuel pump does prime, all 4 plugs do have spark, and there are no CEL codes.
Old Oct 30, 2014 | 05:56 AM
^When the engine won't start?
Does the CEL work?
Old Oct 30, 2014 | 05:59 AM
fmxrydr's Avatar
Correct when the engine won't start fuel pump is priming and plugs have spark, I will have to double check tonight to make sure that the CEL is working though thanks for the tip.
Old Oct 30, 2014 | 06:01 AM
Only when the engine won't start:
Also check whether the spark is bright white. If spark is deep blue, orange, or yellow, it may be a weak spark issue.
And check whether fuel gets to the cylinders.
Old Oct 30, 2014 | 06:03 AM
fmxrydr's Avatar
Ok ill check for it, probably won't be till this weekend before I get a chance to check all of that out. Ill post what I find when I do though, thanks for the help so far.
Old Oct 30, 2014 | 06:05 AM
FYI - You are under no time constraints on a car forum.
HondaNoob92
May 17, 2018 04:50 PM
White Boy Hatch
10
Oct 10, 2013 06:47 PM
bucknastty
Jan 15, 2012 12:49 PM
gsrbeast
Aug 31, 2010 09:39 AM
ek_b16
Sep 7, 2005 10:35 AM
