Boosting my f23a automatic
Old Oct 28, 2014 | 04:07 PM
404jdmaccord's Avatar
Icon6 Boosting my f23a automatic
Well this is going to be my first car to boost and i been looking on you tube to see if anyone has done it but have not seen any videos if anyone has done it et me know or send me a text 7063869301 99 accord
Old Oct 28, 2014 | 10:14 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: Boosting my f23a automatic
Biggest problem with modifying OBDII Hondas is that they are not readily tuneable. Although they were OBDII the system was still a chipped system, non flashable like like other makes. So tuning becomes quite a bit costly as blank chips are not cheap. Most revert to an OBDI system to easily tune or flash the system like with a Hondata piggy back. And to further complicate that, there are no off the shelf systems for use with AT cars for Honda. Your trans was only ever used in OBDII cars, and has extra pressure sensors and linear valves for the PCM to control. I would advice against trying to do anything to your current drivetrain beyond simple bolt ons.
Application Selection Wizard - 2008-2010 Accord
That pretty much sums it up.
Old Oct 30, 2014 | 06:00 PM
accordturb96's Avatar
swap it for a manual, Ive done it, worked great just put a better clutch in when you swap
mikein21061
15
Nov 2, 2015 06:26 AM
sc95delsol
Oct 8, 2007 07:38 PM
redboost10
Feb 1, 2004 09:22 PM
B16A1-EF9
Oct 26, 2001 07:50 PM
