FS: MSD Pro Billet Distributor
Moderator in Chief
I am selling a complete MSD Pro Billet Distributor CDI setup. It comes with everything you need to upgrade your ignition to a CDI system. The distributor has an internal digital hall effect cam sensor. The coil is a powerful 115mj. I also have a spare coil and spare distributor cap and rotor. The distributor is brand new in box. The plug wires are new OEM wires which will come with the distributor for free.
MSD Pro Billet Distributor (8488) - New in box
http://www.summitracing.com/parts/msd-8488
SCI CDI ignition box (6305)
http://www.summitracing.com/parts/msd-6305
Two SC Blaster Coils (8235) - 1 used, 1 new
http://www.summitracing.com/parts/msd-8235
Pro Billet Distributor Rotor (84674) - 1 new
http://www.summitracing.com/parts/msd-84674
Pro Billet Distributor Cap (84314) - 1 new
http://www.summitracing.com/parts/msd-84314
All this would be $865 retail.
Package deal for everything is $400 shipped.
PM me or email muckman at gmail
Moderator in Chief
This will work with all stock and aftermarket ECUs as it is a direct replacement for the stock distributor.
The connector is OBD2 but MSD sells an OBD1 adapter for $30.
http://www.summitracing.com/parts/msd-8864
Moderator in Chief
Yes I ran the MSD setup a couple years ago. I had a warranty issue with the distributor and they sent me a brand new replacement distributor. Now I am parting out the engine so I don't need this setup.
Moderator in Chief
I had the screws on the rotor loosen and the rotor came off. It trashed the cap and damaged the distributor shaft. Turns out I was sent an old rotor set made before they started included screws pre-threaded with loctite. MSD sent me a brand new distributor, no questions asked. They have great customer service.
Mikeflg
Engine Management and Tuning
Jan 10, 2012 06:01 PM
Sean-Ratchford
Feb 17, 2005 02:40 AM
