b16b rebuild
Old Oct 27, 2014 | 09:27 PM
aeros's Avatar
Default b16b rebuild
So I decided to start my own b16b all motor rebuild.
Back in 2012, I hydrolock my motor and it have been sitting there ever since. So this winter I decide to tear everything down and rebuild it.
Plans as of now:
b16b bore and hone to 81.5mm
using GSR crankshaft to stroke it to a 1.8
oem GSR rods
nippon PCT 81.5mm pistons
ACL std race bearings
ARP headstuds and rod bolts
stock ctr tranny
b16a head pocket port by headgamez
crower stage 3 cams w/ steel retainers, valve springs, and keeper.
skunk2 intake manifold w/ 70mm tb
rdx 440 injectors
4-1 narrow header straight into a buddy club spec 2 exhaust
go-autoworks 3inch CAI
pics coming soon!
Old Oct 27, 2014 | 09:32 PM
Acura 95's Avatar
Default Re: b16b rebuild
Who knows how to fix an idle issue on a 1995 Acura integra?
Old Oct 27, 2014 | 09:38 PM
93egSLEEPER's Avatar
Do you plan on running this setup on pump gas?
Old Oct 27, 2014 | 09:48 PM
aeros's Avatar
Yup, I only have 93 octane around here. The closet gas station with 100 octane is about a hr away one way.
Old Oct 28, 2014 | 06:23 AM
Just curious. Thats quite a bit of compression for pump gas. It's not impossible, but you will need to compromise some tuning to make it safe...at least IMO. JDM ITR slugs or P30's aren't an option? Make sure you clay that motor when it goes together. Big domes and big cams take special attention.
Old Oct 28, 2014 | 09:54 AM
aeros's Avatar
I'm trying to get 11:5+ compression so i can use the benefit of the stage 3 cams from crower, that's the only reason why I'm planning to use the PCT piston to yield that goal. I'll be using s300 for tuning and i know my tuning will have to be on point so it won't cause detonation.
Old Oct 28, 2014 | 01:17 PM
You can get over 11.5:1 without using the PCT's. Use JDM pistons....P30's or P73's
Either of those will allow you to really tune the car on pump gas
Old Nov 2, 2014 | 12:42 PM
GIZZ - EXV's Avatar
Loved
A familiar story, I've been sitting on my b16b for a while. Assembled in in 2010, sitting on my bench now. I wish I took some more pics before buttoning her up, high hopes for the old b once it's in. Sneaky setup, "it's just a 1.6!!!"
Will you hit the drag strip? What's the goal?
Let's see some pics!
Old Nov 2, 2014 | 03:03 PM
NewBorn_EG's Avatar
i think the compression will be over 11.5 but i mite be wrong
wreckeddc4
10
Jul 9, 2010 03:36 PM
JDM809
Northeast (Sales)
Oct 15, 2009 07:45 AM
Tbone
51
May 20, 2008 12:31 PM
lsvtechatch92
Nov 4, 2007 09:48 AM
jdmEFsedan
Dec 24, 2004 12:13 PM
