dirty drum brakes
Old Oct 26, 2014 | 07:31 PM
johnlvs2run's Avatar
Default dirty drum brakes ~ is water okay?
I've not done the back brakes before, and have a couple of questions.
The shoes have more than 1/8" of thickness. Is this enough and how many more miles should they last?
The brake housing is caked with brake dust, including on the surface of the shoes.
Can I clean it out with brake cleaner without lubing, or will the cleaner wash away all the lube.
I have CRC brake & caliper grease, and am concerned about getting it on the brakes, or is lubing not a big deal?
Can I clean the housing with water instead, and not have to relube the parts?
Old Oct 27, 2014 | 08:42 AM
EsotericImage's Avatar
Retired Moderator
Default Re: dirty drum brakes
Use the brake clean.. thats what its for.
Might as well replace the brakes since the hard part is done already.
its not hard to re-lube
Old Oct 27, 2014 | 08:47 AM
Okay, thanks very much.
Is it okay to use water on the cylinders (to protect them), and brake cleaner on the rest?
Old Oct 27, 2014 | 09:04 AM
Retired Moderator
Dont use water anywhere. Use brake clean and if you remove any lube, then just re-lube.
Brake clean is just that.. Brake cleaner. So use it.
Old Oct 27, 2014 | 10:36 AM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Old Oct 27, 2014 | 12:57 PM
Thanks much for the help! I used the cleaner and just avoided the ends of the cylinders. The buildup wasn't as bad as I thought.
teamhonda_johnb
Honda Civic (2001 - 2005)
Mar 1, 2009 07:25 PM
Civic_07
Suspension & Brakes
May 5, 2008 09:31 PM
Nessal
Sep 3, 2005 06:24 PM
sleepyhamsterlx
Mar 15, 2004 07:15 PM
servion
Feb 26, 2004 05:07 PM
