SC 1994 Honda Civic EX shell
I have a very clean and pre-stripped Civic shell just screaming to be built ---- RUST FREE. The car comes with original doors, trunk, sunroof (if you want it) and tan interior including dash. No seats and no suspension components. Clean title in hand.
The car has been completely stripped of all components minus the e-brake cables. The front end was professionally sandblasted by Dean's Sandblasting ($250) and then I started to shave and seam weld the front end. The seam welding can be finished by me for a couple hundred more or you can do it yourself, doesn't matter. The rear spare tire well was cut out so it could be replaced with a brace and a flat pan for aerodynamic reasons. Everything pretty much stopped on the vehicle due to having 5 other projects.
Car has four drilled and tapped steel plates welded to the underside of the structure so that 4 - 800lb casters can be bolted on. We did this so that the car can be moved easily and stored better when not in use, even after it is built. The casters were $240 and will also be included.
I have a lot of time and money invested in this, and I am losing a lot of money. For anybody looking to build a drag Civic or a HPDE car, this one is ready with most of the actual not fun hard work already done.
Asking $450 obo
Text me @ Eight4Three-53two-OneTwo7Four
Asking $450 obo
Still up for sale. Great little shell, getting tired of storing it. Someone scoop this up from me! I might even deliver if you are close enough.
