b18c4 engine b16b pistons ?
Old Oct 25, 2014 | 10:38 AM
070-racing's Avatar
Default b18c4 engine b16b pistons ?
Hello my english is not verry good so i do my best.
I have a b18c4 engine and i have a set b16b pistons .
Now i like to put the pistons in the engine .
Now i read some forums that the space from piston to head and piston to valve need som work.
Anybody can help me with som info
The block is
B18c4 engine
Ctr pistons
Itr spec 98 cams
Skunk 2 valve springs and retainers
I hope to get som info if this going to work or what i must do to let it work
GreetZzz
Old Oct 25, 2014 | 02:04 PM
wunfstgsr's Avatar
Loved
Community Favorite
Default Re: b18c4 engine b16b pistons ?
Ill chime in since your foreign and i can understand how hard it could be sometimes.
Take my advise and forget the b16b pistons, The dome is too high on those pistons and will need careful assembling like for example claying the motor to make sure your not going to get piston to valve contact! Your comp will be pretty high as well. Iv built many of these engines!
Use JDM Type R pistons! they will bump the comp up more than standard USDM Type R pistons, These pistons will work much better. you should be around 190 hp with a good tune depending on the rest of the engine setup. A better exhaust manifold and intake manifold and a 2.5'' cat back will give you close to 200hp.
Old Oct 25, 2014 | 09:58 PM
OMG's Avatar
OMG
if he has enough octane it will work good
Old Oct 25, 2014 | 10:20 PM
JKaze's Avatar
10 Year Member
If this is streetcar and no E85 available, I also recommend P73-00 pistons instead PCTs. With your P72-cylinderhead these gives you nice CR and you can still run with pumpgas.
Because you wrote "B18C4", I assume you live somewhere in Europe. So, EDM ITR B18C6 also use these same pistons as JDM ITR engine. Actually, only significant differences between these two engines is header and ecu. So don't pay "JDM-extra".
Something else than stock intakemanifold would be also good upgrade (if you don't have already).
Old Oct 26, 2014 | 04:55 AM
070-racing's Avatar
Thanx for the info yes i life in the netherlands
And i got a e85 pump within 3 miles
so i can get e85 nearby
The rest of the setup for now is going to be .
Hytech big tube
Edelbrock victor x / skunk2 ultra.
70 mm throttle
Blox velicoty stack .
1 year a go i had a lot of setbacks
And i solt my eg b16 high boost car
Now i wanna pick it up again and start over so the setup is for now .
The plan is to go dart engine b20 all motor / or semi turbo
So i just want the best engine power for now with the parts that i already have .
I do have a set b16a pistons and a b16b zo you say better b16a .
Build 3 hondas in the past
1 all motor b20 271 hp 244 torq
2 b16 turbo fuily build hit on dyno 670 hp on 1.4 bar boost als 550 torq
Mis my cars
Thanx for the help
kennie555
Feb 21, 2013 04:32 PM
HmgLauj69
May 24, 2009 02:28 PM
H.wood
Apr 30, 2006 04:36 PM
BodyKits NW
Nov 29, 2001 02:35 PM
BABY NSX
Sep 20, 2001 08:05 PM
