95 Accord V6 - C27A4 - Engine photo
Hi folks,
I am in the process of swapping out a C27a4 in a '95 Accord. The PO's mechanic had partially disassembled the dead engine before I got the car and he dumped everything in a box. I'm close to having the engine swap completed but now I'm at the final details and it's not too obvious how the throttle cables are routed and adjusted at the throttle body. Naturally neither of my reference books actually show the routing for the V6...only for the 4 cylinders.
Does anyone have a good pic of the throttle body and adjusters on the C27a4 that they can share with me?
Thanks!
Thanks!
Can't upload pics right now but the routing is really simple. The throttle cable bracket bolts to the throttle body with 2 10mm bolts, and the throttle cable goes on the inner throttle rotor closest to the bore. There are two locknuts on the end of the cable tube used to adjust cable play between the bracket and throttle body. The cruise control cable comes across the engine from the box on the passenger side and there are two brackets on the intake manifold to hold the cable, and the cable is then connected to the outer throttle rotor. From there the iacv has to be plugged in and coolant hoses connected, and fitv coolant hoses connected. If still needed I'll try to find pics from when my stock throttle body was installed, although the throttle rotor is hidden in most pics since its toward the rear of the engine.
cloudconnected85
Nov 7, 2010 04:35 AM
