Honda Accord & Crosstour (2003 - 2012) 2003 - 2012 Honda Accord and Inspire
accord k24a4 oil leak... common?
Old Oct 24, 2014 | 11:17 AM
Charlie Moua's Avatar
Default accord k24a4 oil leak... common?
I have a 2004 accord k24a4
It has +180K on it, still running like a champ but recently noticed it's dripping a lot of oil.
It's not the oil pan gasket, but seems to be spewing on the oil pump side and getting all over my engine belt.
Q:
1) is this oil leak pretty common for K series?
I know for most d-b-h series, the REAR main seal tends to go out well before the front main seal.
2) is there any other seal (other than front main seal/oil pump seal) which could be leaning around that area?
Thanks - Charlie
Old Oct 24, 2014 | 06:10 PM
BLKFLSH's Avatar
Default Re: accord k24a4 oil leak... common?
I would clean the area with carb or brake cleaner, then try to spot the source of the leak before it spreads.
Old Oct 25, 2014 | 07:51 AM
MSchu's Avatar
My Name is Nobody
is it common for an engine with 180,000 miles on it to leak a little oil?
really?
Old Oct 27, 2014 | 09:26 AM
^^^ lol... i guess you don't know the answer then. go troll on the GDD section = )
the past 8+ hondas i've had where high milage and none have ever leaded oil on the oil pump side.... so i figured it must be a K series thang..
Old Oct 28, 2014 | 11:50 AM
johnsc2235's Avatar
In short yes semi common, it is typically the front crank seal that goes which then spins up the oil everywhere and makes a mess. Its very easy to do and if you are replacing that
I typically reseal the side timing tensioner cover at the same time since its only three bolts
and your all ready in that area
somick
Aug 15, 2017 08:14 AM
num1_tuner
Feb 16, 2012 09:25 PM
Deadwood
Jul 12, 2010 05:05 PM
noodlez1390
Jan 5, 2009 04:29 PM
GruvyTune
Jul 5, 2002 08:57 AM
