brakes creak on passenger side of car
98 bone stock civic hatchback cx - Canada
hi there
all of a sudden my passenger front of the car started to creak. like an unoiled heavy door hinge. The creaking only occurs tho when I am braking at speeds of less than 20km per hour. Sometimes also when I am rolling in neutral. Seems to be more prevalent when its wet and rainy outside. Cant seem to figure out what it is. I tried pushing down on the shock and it bounces up fine with no sounds.
Are these signs of a bad lower bj? I tried to find something similar on the forums but nothign that matches this.
anyone know?
thanks,
hi there
anyone know?
thanks,
99.9% agree
only last thing i'll say is maybe part store brakes not liking the cold, my 00 Si's brakes are squeaking now with the almost 0 degree weather. I won't go as far as to so you have hawk HP+ pads that's extremely unlikely(race pads)/
it also makes the sound in when i turn the steering wheel side to side at low speeds when im rolling. Are these indicators of the lower ball joint? i should add that i dont have power steering. Never came with the car.
are these still brake related if they occur when im not touching the brakes?
sorry about that, was trying to give the most accurate description
http://vidmg.photobucket.com/albums/...psgtevqh35.mp4
is a clip of the sound it is making. I hear it when i press the brakes at slow speeds also when I am moving at slow speeds (1st gear up to 10-15km/hr. Its almost as if when I am moving, something is sticking and creaking apart as I get moving again and finally lets go when i get above 15km/hr.
I pressed down on the car and the struts dont seem to be making any noises and come back up fine with no bounce either.
