Rhd conversion question
Old Oct 21, 2014 | 07:33 PM
Rexmills11's Avatar
Default Rhd conversion question
So after combing Honda-tech for years for many questions and problems with my Ef over time, I finally decided to join Honda-tech,
I have since gone into another direction with my 91 Crx hf. My question is :
I am going and have started the disassembling process in order to convert my vehicle to rhd, do I have to remove the front windshield and rear crossmember out of the vehicle?
I'm pretty sure in order to make the process easier , yes remove the rear crossmember. However, I am unsure about the windshield...
Any help from you guys would be greatly appreciated
Old Oct 21, 2014 | 08:12 PM
ef2_civic's Avatar
Default Re: Rhd conversion question
U pretty much answered ur own question. Yes on cross member but no on wind shield unless u want to. But not necessarily
Old Oct 22, 2014 | 07:45 AM
Rexmills11's Avatar
Sweet, thank you for the feedback! all I have left to do then is the rear cross member, and the brake lines/ fuel lines that run into the firewall, then start removing the firewall correctly!!!!! I need to do extensive research to make sure that the changeover is done right, and not a hack job.. Thank you again!
Old Oct 23, 2014 | 01:04 AM
shopa's Avatar
You can damage the windshield when removing the firewall and will cost you more.
Cheap always become expensive.
It's will more easy to work if you remove it.
Old Oct 23, 2014 | 01:57 PM
KevinEF7's Avatar
Alot easier if you remove it, worth the $60 a mobile guy would charge
slo88hatch
Apr 5, 2009 10:32 AM
Glepage22
Honda Civic (2001 - 2005)
Oct 26, 2008 09:02 PM
ThePest
Mar 9, 2006 10:31 AM
SparkeZ
Jul 10, 2004 04:43 PM
