Which REAR wheel bearing for 99 ex w/ Drum brakes & ABS
Old Oct 21, 2014 | 04:25 AM
hondatuner020's Avatar
Default Which REAR wheel bearing for 99 ex w/ Drum brakes & ABS
Ok so i have a 99 civic ex sedan (US model made in Canada) with ABS, when buying wheel bearings it ask abs or non abs, but often times it indicates the rear abs wheel bearings are for disc brakes. Is the abs only on the front of drum brake civics? Is there no abs on the rear of drum brake abs equipped vehicles?
Old Oct 21, 2014 | 04:42 AM
tony_2018's Avatar
Fish Twig
Default Re: Which REAR wheel bearing for 99 ex w/ Drum brakes & ABS
You might want to pull up the exploded view of the rear drum brakes on an honda oem parts site. That helps.
Old Oct 21, 2014 | 04:47 AM
It says abs, but dosnt show the abs ring on the bearing..... another layer of confusion
Old Oct 21, 2014 | 05:08 AM
tony_2018's Avatar
Fish Twig
Honda parts sites rarely get it wrong, you can cross reference that part # to any other civic and see for yourself between the abs and non abs bearings.
Old Oct 21, 2014 | 09:39 AM
confirmed by removing the drum brake, the car has 4 wheel abs. there are abs rings on the wheel bearing / hub assembly.
JRTegman987
Dec 2, 2023 04:16 AM
alexg103
Feb 23, 2010 11:16 AM
krkskrw
Honda Civic (2001 - 2005)
May 27, 2008 06:23 PM
youdontknowmeeither
Dec 20, 2006 08:50 PM
psegs80
Dec 25, 2005 05:05 AM
