Honda Civic (2006 - 2015) 2006 - 2015 Civic Forums
Fd2 valve clearance
Old Oct 20, 2014 | 12:23 PM
Kadene Irwin's Avatar
Default Fd2 valve clearance
Can anybody help, I can't find any data on the internet to tell me what my valve clearance should be. Must be an fd2 k20a because it's different to ep3/dc5
Please help :/
Old Oct 20, 2014 | 12:46 PM
m_shake's Avatar
Default Re: Fd2 valve clearance
How do you know it's different if you don't even know the clearance?!
Old Oct 20, 2014 | 12:52 PM
Because it has different pistons and a higher compression ratio than the ep3/dc5. Just want the measurements for the intake/exhaust valves
Old Oct 20, 2014 | 03:03 PM
m_shake's Avatar
All other K-series with real vtec are the same spec, just like all b-series vtec shared the same spec.
01-06 rsx k20a/z and 06-11 civic si k20z3 is the same spec
0.21-0.25mm intake
0.25-0.29mm exhaust
Also having 0.2 more compression over a dc5 doesn't mean dick as far as valve clearance is concerned. Also fd2 ex cam is same as dc5.
And just for ***** and giggles, the s2000 f20/22c uses the same k-series specs i posted above
skiracer8148
Feb 29, 2012 09:06 AM
jherbie
Jan 23, 2007 05:09 PM
ILcrxsi1
Mar 10, 2006 10:09 AM
KURUPTinc
Jul 2, 2005 06:12 PM
Pompiuses
May 5, 2005 03:08 PM
