wot 6k rpm cuts off
Old Oct 20, 2014 | 05:22 AM
BIGef's Avatar
Default wot 6k rpm cuts off
i have an 89 civic b18 obd1 tuning with neptune rtp
i have a problem when doing 3rd gear pull at 6k rpm its will bog/cut then pick up right away and keep going.
i was thinking it was the distributor.
as you can see in the video right when you see it hit the lag the rpm hits 0.
need advice TIA
Old Oct 21, 2014 | 06:57 AM
motoxxxman's Avatar
Default Re: wot 6k rpm cuts off
vid is set to private, we can't view it currently
Old Oct 21, 2014 | 10:27 AM
BIGef's Avatar
Thanks for noticing that it's now viewable
Old Oct 21, 2014 | 06:01 PM
VegasInvasion's Avatar
I'm Huge In Japan
it's shutting down all data including VSS, which isn't part of the distributor. That tells me it's either an ecu issue or an electrical issue. Clean and tighten all your grounds and battery terminals, check for shorts, try another ecu.
If you've relocated your battery, I guarantee that's your problem.
PR8urVtec
May 20, 2016 05:19 PM
rpmraper
19
Jul 12, 2011 01:53 PM
zm_dawg
Oct 10, 2004 12:41 PM
hyperlite1080
14
Apr 12, 2004 01:17 PM
Vince_badaz
May 14, 2002 01:07 PM
