Fully built b18 turbo hardstart/extended crank
Old Oct 19, 2014 | 02:28 PM
Tealandpeel93's Avatar
Default Fully built b18 turbo hardstart/extended crank
I have a 93 eg fully built b18a1 ls with pistons, rods and cams and all that. It has a 3bar omni map sensor and 750cc rc injectors. Running or ATTEMPTING to run on an s300v3 with a basemap when the cars running wideband readings are around 12 to 15 sometimes it varies a little more but the car never immediately starts, almost as if it has to get warm and then starts. Will crank for a while and attempt to start. Then usually after that point it can be started easier. Any other information needed i will gladly share im kinda stumped at this point.
Old Oct 19, 2014 | 04:43 PM
Default Re: Fully built b18 turbo hardstart/extended crank
BUMP anything helps
Old Oct 19, 2014 | 04:50 PM
BUMP anything helps
Tealandpeel93
Engine Management and Tuning
Oct 27, 2014 08:46 AM
soupE__
Feb 23, 2012 08:49 AM
b19coupe
Sep 25, 2007 07:48 PM
JayDiem_k20_Dc5
Jan 11, 2006 08:18 PM
baonest
May 27, 2002 09:20 PM
