Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Car won't start
Old Oct 18, 2014 | 02:25 PM
Ralph3991's Avatar
Icon2 Car won't start
Hello all,
I have a 01 Civic LX. Today I had to replace my cooling system fan. I took the battery out in the process to make clearance to pull the fan out. I put everything back together and now the car does not start. The starter does not even engage. The headlights are flashing, the dash lights are flashing and the radio lights are flashing and the internal speaker is beeping (like when you put the key in the ignition).
I noticed that the car has an aftermarket alarm system in it (IR-s Code Alarm). I found the alarm system when I was trying to find the under column fuse box to check my fuses. Looks like the fuse box was relocated for security purposes. I have no idea what to do. Any advice would be greatly appreciated.
PS: I do see the alarm system under the column. That is how I was able to see who makes it. All the wires are spaghetti from whoever installed it.
Old Oct 19, 2014 | 12:11 PM
Ralph3991's Avatar
Default Re: Car won't start
Originally Posted by Ralph3991
Hello all,
Hey everyone I fixed the issue. There was a small push button under the dash. I pressed it and turned the key at the same time to reset the security system and the car powered on.
Old Oct 20, 2014 | 10:01 AM
lazlong's Avatar
You beat me to it. Several times I've had friends call me with the same symptoms- "it's just acting crazy!". I go check it out and find a switch they accidentally kicked or kneed.
unlucky jess
17
May 3, 2013 01:52 PM
whitelotus420
Aug 1, 2008 09:05 AM
DoyouVtec
Feb 26, 2008 01:46 PM
alonzo_civic
Feb 24, 2008 02:37 PM
ridin98civic
Apr 16, 2007 10:02 PM
