new to honda, need help
Old Oct 18, 2014 | 01:25 PM
hiwaydog's Avatar
Default new to honda, need help
I recently purchased a 93 accord LX 2dr from the local charity auction. the car is really clean, and I loved it right up until the cam locked up (my fault, i Knew the oil pressure was low). anyway, I put a junkyard engine in it, it runs better than it did before, the only issues I have are that the speedometer now doesn't work, and the d4 light keeps flashing.
I did not remove the transmission, only the engine, and I know i reconnected all plugs that i pulled loose in the process. My only thought is that I must have pulled a wire loose somewhere inadvertently, since the speedo was working fine before.
can anyone point me in the right direction as to where to look?
I am a seasoned mechanic (i work on boats, jet-ski's, quads, and golf carts for a living) I'm just completely unfamiliar with hondas
Old Oct 18, 2014 | 05:06 PM
MAD_MIKE's Avatar
MM Gruppe B
Default Re: new to honda, need help
Passenger kick panel, look for a two wire blue connector floating in space.
Jumper that connector with a wire, turn the key to II(ON), watch for any blinking CEL or D4 codes.
Old Oct 19, 2014 | 10:51 AM
hiwaydog's Avatar
thx, ill give that a try tomorrow
Old Oct 22, 2014 | 06:43 PM
hiwaydog's Avatar
ok, i'm getting 2 codes, code 17 on the CEL, and code 4 on the D4 light, which from what i have read points to the VSS, but since it was working fine before i swapped the engine, I don't understand why it decides to quit now, unless maybe I inadvertently pulled one of the wires loose form the connector when disconnecting it, which i guess is a possibility. I will take a good look at that connector tomorrow.
Old Nov 2, 2014 | 05:04 AM
hiwaydog's Avatar
sorry for the long delay on the update, the issue is partially resolved now, meaning that the speedo works most of the time.
I pulled the connector, and found that one of the contacts on the female side was fouled with some green corrosion. I cleaned the connector with throttle body cleaner and compressed air, and now the speedometer works most of the time. sometimes when i first get in the car it doesnt work, but will start working after a few miles, but now it also will fluctuate wildly before finally settling down and reading correctly. (I verified the accuracy with a gps app on my phone.) I think i need to take the VSS apart and clean it.
rcruz
Apr 5, 2019 05:23 PM
TheTix
Jul 3, 2017 07:11 AM
jonsmith74
Jan 2, 2016 08:59 AM
h2omusc
Dec 5, 2014 03:29 PM
miedosoracing
Mar 24, 2004 06:32 AM
